XP Pro SP1 Prob with NIC disappearing
If it's built into the motherboard try updating the BIOS or checking the motherboard from earth faults near the NIC port.
If it's a separate board then try changing the PCI slot its installed in.
You might also want to check through the computers IRQ/DMA etc resources and see what the NIC is sharing resources with, if it's something like a sound card then try disabling it and see if it improves stability.
The other alternative would be to boot off a linux CD (Knoppix etc) and see how the network behaves itself then :)
