iirc u are fine up to 80.C with that cpu.
it could just be warmer if its slightly more clogged up with dust etc....
u have nothing to worry about regarding the cpu.
have u run a game or anything to see what the temp rises to?
is the fan on the cooler running?
There are two fans inside the Optiplex GX270 (slim desktop), one on the psu and one on top of the heatsink. Both fans are running and there no sign of dust build-up.
Having siad this, the fan on top of the heatsink is a tiddly affair compared to larger pc's of more recent times. If there was a way to customise a larger more powerful fan into the heatsink arrangement I would do, but that's impossible because your are totally restricted by the casing / power supply / wiring. The GX270 is one of the most restrictive case interiors I have seen, it's like a proto lap top basically. But the fact you can just clip it open and shut when you want is a massive if unintended advantage, if you do need to cool off the cpu.
btw. that P4 cpu is more powerful than my 2Core, 2.80GHz compared to 3.06GHz!
If they are old sometimes the thermal compound can dry and crack meaning the heat sink does not interface with the CPU properly, although those old P4s run very hot anyway. Also, it is categorically NOT faster than you dual core as the clock speed is not the only measure of chip performance. As an example, my laptop contains a 1.3GHz Penryn core 2 duo and has equivalent or greater single core performance to a 3.2GHz Pentium 4.
Running XP pro should not affect the temperatures at all, I've run home, windows 2000 and even windows Vista on a P4 system and the OS used did not affect the temperatures in any way. Differences are to be expected due to different heat sinks, thermal compounds, age, quality of CPU, case and even power supply dumping heat into the case.
