I have just partition my HDD 2 x 200Gb
copied 1 partition to the 2nd.
modified the new copy.
rebooted, to made sure both worked ok.
deleted 1st copy moved the new copy to the begining using paragon disk manager 8
rebooted and left paragon to do its business.
returned 3 hrs later to find it had frozen @ about 99% complete.
as expected it would not boot!
Used repair on the XP CD bootcfg /rebuild, which it did.
But still won't boot.
I can view the HDD details on a paragon rescue disk.
Its listed as
HD 0,
Type Primary,
File system NTFS,
Active yes
Hidden No.
I can change SID etc from the rescue disk, but to be honest I dont know what they do
Any Ideas,
Its listed as
HD 0,
Type Primary,
File system NTFS,
Active yes
Hidden No.
Any Ideas,
