XP - scheduled chkdsk will not run
25 Aug 2006
Hey all,
I am running XP on a laptop and tried to do a defrag. The system informed me that i had to run chkdsk first, which would run at next start up.
Upon the next start up i got a message like:
cannot access directory file system is ntfs
And the system boots as normal. I am getting this message everytome i boot up now.
Any help on how to get rid of this message or to run the chkdsk/defrag?
Ta!
Try hitting F8 during startup and choosing Safe mode with command prompt. You should then be able to run it from the dos prompt.
