Got a problem which I've tried searching for on t'internet but with no joy. It's nothing that affects my use of XP parsae but it is annoying. I know a fresh install will fix it but if I can get away with not... you get my drift.
Anyway down to business. Symptoms include
Non functioning WMP, not matter which version I try/how many times I install it (This includes the embedded one in firefox too)
User CP is completely blank, i.e, It opens... but there's just a white space
IE Works, but it won't load update.microsoft.com, neither will firefox (Although this is normal?) but it won't with the IE tab plugin either.
I assume this is a config or .dll file problem or something like that? Anyone know how I can get them to work again ( I am assuming they are connected as they all died at the same time)
Cheers for any help
I think there were some other things but can't remember right now. I do know that NON of my non-Microsoft seems to have broken at the same time
Cheers for any help
