XP Sharing
12 Jun 2005
Hi there,
I am trying to access the C drive on another machine on my network via "\\ComputerName\C$".
It prompts for a username and password...
I type in the admin username and password for that machine, but it says its incorrect and doesn't let me in.
Is there something I have to setup?
Thanks.
so you have pc1 and pc2
from pc2, you're typing \\pc1\c$ then getting a username prompt, and you're typing in the login for pc1 and it's not working?
Correct.
EDIT: Could it be to do with a service i have disabled? - I mean I can share folders normally....
administrative shares could be disabled on pc1 (in gpedit.msc i think)
can't remember if it'd still show the username/password prompt if it's off (when it tries to reach \\computername, not sure if it resolves that first, then the share...
Got no idea how to check this :/
Got the Group Policy window open, but no idea where to go from there.
Now saying it can't have multiple connections...:/ (that is using any username/password combination)
(I have been pratting around....lol...)
