- 14 Jul 2005
- Bristol
Recently reinstalled XP as I was having some issues with Vista (due to soundcard which I want to use).
I don't like the default XP themes and so run it on 'Classic View', but it's a bit plain and I'd like to skin it.
The problem then comes that the only application I know to do this is WindowBlinds, which is a nice enough application, but it does have memory usage issues and often used to break when I had it on a previous install.
Are there any other ways in which I can change the skin that'll not break or eat memory?
InvG
InvG
