XP Sp2 and IE7
11 Oct 2005
Derbyshire
Just wondering, I am soon to do a reformat on my main pc, and if i download from M/Soft SP2 when i reinstall XP Pro then SP2 will the latest version of SP2 have IE7 on or will I have to install that seperately as well ?
thanks, could find the answer on Microsofts pages
No SP2 doesn't include IE7. If you're doing a fresh install why not create a SP2 slipstream disc? After you've created that disc a fresh install of your new CD-R means SP2 is pre-applied to the install, so you don't need to install SP2 after the first login. So it saves time and space (SP2 still keeps old files even if you don't ask it to)
http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp
I've created SP2 install disc and it works :)
