XP taskbar - No right-click
18 Oct 2002
Royston, Herts
Hi folks,
I'm hoping someone can help me with a minor irritation which is beginning to bug me. My work laptop has developed an odd little issue. If I have several programs running and want to switch between them then ALT+TAB works fine. If I try to switch by using the taskbar I have to click 3 or 4 times, during which the desired program will minimise and then pop back up at the front (as I want). Also, if I try and right-click on a running program to close it nothing happens. No right-click menu appears at all. Right-click works on the actual taskbar itself and on the desktop etc so I know that my mouse is OK. :confused: Using the keyboard right-click button doesn't work either so I assume that some setting is OFF or some such.
Any thoughts?
