xp vs 2k
xp has more optimised boot time, and is more stable
if explorer goes in 2k, a lot of the time, you just HAVE to restart
xpsp2 is awesome
XP with Service Pack 2 is the only Windows OS you should consider unless you have good reason to use an older version.
TrUz
xpsp2 is awesome
If Explorer goes anytime and it doesn't come back automatically then just load up Task Manager (Ctrl+Alt+Delete) and goto File->New Task then type in "explorer" and hit OK.
