XP64 and the Xbox 360.
21 Oct 2002
It appears that it is rather difficult to connect a 360 to windows, as the windows media connect software wont install.
After googling though i found these instructions to make it work:
http://extended64.com/blogs/andre/archive/2005/11/22/1523.aspx
However, they might as well be written in urdu for all i can make of it, someone decipher it into instructions a half wit like me can understand.
Namely "create a 32bit command window" WTF?
To start a 32-bit command prompt, follow these steps:
• Click Start, click Run, type %windir%\SysWoW64\cmd.exe, and then click OK.
