XP64 trial query
30 Aug 2003
a mate of mine has a disk with XP64 on it but to me it doesnt quite look right once he has installed it how can i check if its ligit or not? without going onto microsoft (just incase its not ligit)
is there somewhere in the system i can check it?
When you login to the machine, it will say so in the lower right hand corner of the desktop. Unfortunately I cant locate a screenshot to show you what I mean, but if there's no white text making it obvious that it's a trial, then it's quite probably pirated.
You could also just boot off the installation CD again to take a look. The first or second blurb explains that the image is of a time bombed trial.
yes it will say evaluation copy in the lower right it will evan say it if you change the wall paper
you will need a key to install and it will need activating
if you do not have a key order the trial from MS they will email you a link and in that email will be your key
but check if you have all the required drivers
