Xpenology on a microserver - network speeds
10 Jan 2009
Hi guys, I've noticed a few times now that I've had slow network speeds (onboard nic) coming from my xpenology machine - when I check its only the connection is often at 100mbps not gigabit - if I restart the machine I get gigabit again for a while. Any ideas what I could be encountering?
I suspect the Ethernet lead has some damage and the NIC is dropping the speed to try and reduce the volume of packets that are rejected at the switch/router as unreadable (or it not being able to understand what it's receiving from the switch/router).
Ah thats a really good point, one I hadn't considered! I will try another cable - hopefully its the cable on the outside of the wall and not in :D
Cheers!
Finally had time to have a play around and I'm pleased to say that the server is now stable so as you suggested it must have been an issue with the cable - many thanks I owe you a pint :D
