Hi there,
I've had the XPS 15 for around a week and have noticed some issues. I've used the Dell Command update tool to update the bios and a few other drivers it suggested.
The first issue is the noisy fan. Even if I'm just browsing the internet or when the laptop is idle I still get a noisy fan. It happens much more often than my old macbook pro 2012 did, where I would only hear the fan being particularly loud when it was under stress from certain programs. This is pretty disappointing as I assumed a much more powerful machine and newer machine shouldn't have this problem. Is there anything I can try to fix this or is my machine potentially faulty? It does seem to be a very common problem so is it just a frustrating feature of the XPS 15?
The second issue is whenever I go into the task manager the disk is showing to be at 100% usage. Again this will happen when I'm doing basically nothing with the laptop and the machine is idle. I'm no expert but surely this shouldn't be like this? The CPU and memory usage seem normal for whatever I am doing but the Disk shows 100% no matter what.
Any advice appreciated, thanks. I have the i7, 16gb ram, 512mb SSD model.
