It's an Intel X38 chipset I think. Will be DDR2, probably PC2-5300 as dell usually use the cheapest RAM they can get away with. It MAY be PC2-6400. It should take up to 8192MB of RAM (4x2GB sticks) but that will also be limited by your OS - 32 or 64 bit.
If you get PC2-6400 you should be OK, but as RJC says just run CPU-Z and buy the same spec as what's already fitted. I highly doubt it will be PC2-8500. As for which brand to buy, I don't think it really matters.
