XSPC 200
9 Oct 2008
Somerset, UK
Hi does anybody have a XSPC 200? What are they like? I am thinking of buying one as i am only planning to cool my CPU and dont really need to dual slot version.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-040-XS
is it this one you was after ?
if it is then it's superb for the cpu.
it dropped my temps down to 16c from 25/30 with my tuniq.
i didnt get it from ocuk as i wanted a double rad and found a company that let you upgrade to a double rad for £6.
this was my 1st water cooling project and after many hours spent looking for a good kit i went for this one after many good reviews.
if you need any more info then please contact me via my trust.
I haven't got one, but I've asked before. Appently they are good. But are hit and miss with regards to noise. Some say they are fine, others say they have had dud ones which make a racket.
The XSPC Dual 750 Bay Reservoir & Pump are rated as being much better.
