xspc and d5 vibrating issues
17 Apr 2011
In front of my monitor
xspc and d5 internal pump
well its buzzing like a good un
any ideas to dampen it down, seems the reservoir is vibrating against the case:mad:
drivin me nutttts
Need some rubber or a soggy sandwich in there somewhere to soak up the vibrations. Is it a bay res by any chance?
Had one and took it out a long time ago because of the same problem. Only thing you can do is turn the pump down and try to decoouple the bay res frpm the case as practically as possible, rubber washers or something.
Make sure it is not just the pump itself, mine was making a loud rattling and I RMA'd it - nice and silent now.
