- 29 Aug 2010
- Cornwall
Hi all.
I've been thinking of changing my XSPC X20 750 pump/res combo for a Laing D5 Vario pump. Due to the fact that I'm water-cooling in a CM 690 II case there's not a massive amount of room for a pump or res, hence why I opted for the XSPC X20 750 initially. I'm not sure if this pump is the best and have heard good things about the D5 one of which being the 5 speed settings.
Now because of the space restrictions I was going to put the D5 in a dual bay res like this (except I'd try to find somewhere that actually has them in stock).
Now it look like that res keeps the pump out of the water and allows access to the pump while it's in place. My question is, with the pump in the bay res, can you still get to the speed adjustment mechanism?
Also, probably a silly question, can you connect the pump to a fan controller and control the speed of the pump like this?
Thanks for any replies.
