XSPC D5 Photon Pump/Res Combo
24 May 2011
Hi,
Does anyone know if there have been any reviews for this? Was looking to buy one but can't find any reviews for it.
Has anyone already bought it and if so what do you think?
If he doesn't see this thread I'll give ace modder a nudge in your direction later this evening, he recently used one of these on his new build :)
They're really weighty, and they are reassuringly solid, I have the 270 version, and when full of fluid it weighs a ton. Can be a bit of a pain to fill and bleed air out of, but if you use one of the squeezie bottles with a straw tip it's much better. but it's nice and quiet, I'd get a better led fitted in it probably a bitspower one as teh supplied bulb is a bit on the weak side.
