** XSPC D5 Pumps First at OcUK **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Arriving today and first to market in the world, we have the brand new Pumps from XSPC.
These are re-branded Laing D5 Vario pumps which as most watercooling enthusiasts know, is common practice for most watercooling manufacturers with a D5 pump offering.
This pump is now the only pump used by OcUK in our Tech Labs Range:
Pump Combos
Watercooled Cases
With a choice of a version with no top or a standard version, there is a option for all tastes.
XSPC D5 Vario with Front Cover (1/2” barbs) @ £66.98 inc VAT
The D5 Vario is the ultimate pump for PC water-cooling. It features exceptional performance and unrivalled reliability. The Vario’s speed dial allows you to adjust the pump speed to best suit your system, and the tacho output lets you accurately monitor the pumps speed.
This version of the D5 includes the front cover with fixed 1/2? barbs. It’s suitable for use with 1/2? ID and 7/16? ID tubing.
- 4 Pin Molex and 3 Pin Tacho Output
- Speed Selector Dial
- Maximum Flow: 1200 lph (12V)
- Maximum Head Delivery: 3.7m (12V)
- Voltage: 8-24V (37W Max)
- Maximum Temperature: 60C
- Dimensions: 90 x 108 x 98 mm
Only £66.98 inc VAT.
ORDER NOW
XSPC D5 Vario (Body + Screwring) @ £56.99 inc VAT
This pump ships without a front cover. You will require a D5 top or D5 reservoir in order to use this pump.
- Dimensions: 90 x 57 x 90 mm
Only £56.99 inc VAT.
ORDER NOW
Whats the difference between the XSPC and the Alphacool then?
And why does every make of D5 have different dimensions? They all fit D5 tops right?
None. All D5s are made by Laing.
Think of it as graphics cards. All the chips are made by TSMC then given to manufacturers to slap their silly stickers all over them and give it a warranty.
Atleast I think that's how it is
If it's a D5 it should fit a D5 top
I have run a D5 in my rig since 2005/6. It runs on average 8 hrs a day every day! Still silent and performs like new. Looks like it will last forever.
