Hi Guys
We have an exciting new product up for pre order.
Imagine the performance of a thick watercooling radiator in the same dimentions as a thin radiator.
Then imagine being able to use slow speed fans with a high FPI radiator.
All of these things sound like they shouldn't be possible but XSPC are making it happen.
With reviews incoming, the new EX series are looking set to make a big impact.
Stock is limited on the initial shipment so Pre Order yours now!
XSPC EX120 120mm Radiator - Black @ £29.99 inc VAT
Introducing a new generation of performance PC radiators. The EX series combines the low profile design of our RS series radiators with the high performance of our award winning RX series. This feat has been possible due to several manufacturing advances including, split fins, improved soldering techniques, and welded seam tubes. The EX series has been designed and optimised for low speed fans, so it can offer high performance cooling at very low noise levels.
- Copper and Brass Core
- Black Matt Paint Finish
- RoHS Compliant
- Dimensions: 121 x 35.5 x 155mm (WxDxH)
- Weight: ~358g
- Ports: G1/4?
- Screws: 6-32 UNC
- Fans: 1 x 120mm (2x with push/pull)
Supplied 30mm and 6mm 6-32 UNC screws
Only £29.99 inc VAT.
ORDER NOW
XSPC EX240 120mm Radiator - Black @ £39.98 inc VAT
- RoHS Compliant
- Dimensions: 121 x 35.5 x 275mm (WxDxH)
- Weight: ~507g
- Ports: G1/4?
- Screws: 6-32 UNC
- Fans: 2 x 120mm (4x with push/pull)
Only £39.98 inc VAT.
ORDER NOW
XSPC EX360 120mm Radiator - Black @ £49.99 inc VAT
- RoHS Compliant
- Dimensions: 121 x 35.5 x 395mm (WxDxH)
- Weight: ~663g
- Ports: G1/4?
- Screws: 6-32 UNC
- Fans: 3 x 120mm (6x with push/pull)
Only £49.99 inc VAT.
ORDER NOW
XSPC EX480 120mm Radiator - Black @ £59.99 inc VAT
- RoHS Compliant
- Dimensions: 121 x 35.5 x 515mm (WxDxH)
- Weight: ~843g
- Ports: G1/4?
- Screws: 6-32 UNC
- Fans: 4x 120mm (8x with push/pull)
Only £59.99 inc VAT.
ORDER NOW
- RoHS Compliant
- Weight: ~358g
- Ports: G1/4?
- Screws: 6-32 UNC
ORDER NOW
- RoHS Compliant
- Weight: ~507g
- Ports: G1/4?
- Screws: 6-32 UNC
ORDER NOW
- RoHS Compliant
- Weight: ~663g
- Ports: G1/4?
- Screws: 6-32 UNC
ORDER NOW
- RoHS Compliant
- Weight: ~843g
- Ports: G1/4?
- Screws: 6-32 UNC
ORDER NOW
wacking my order in now
I dont suppose there is any chance you could send the other bits on that order at all ?
