XSPC EX240 radiator fittings?
20 Nov 2011
Hi all,
I'm currently looking to upgrade my cpu cooler from the AIO corsair h100i to a xspc 750 ex240 kit but i want to go the whole hog and go hard pipe even though it's my first waterbuild.
My question is i know they come with 1/4" barbs for the radiators but i'd like to use the primochill ghost fittings in white and just want to know wether these will fit the radiator and pump and cpu block ?
https://www.overclockers.co.uk/showproduct.php?prodid=WC-219-PM
Sorry for the stupid question i just don't want to fork out for like 6 -(7 if i destroy one) fittings to find i can't use them. can any one help?
Most watercooling gear use 1/4" threaded fittings, so you will be fine there.
But the one you linked are for acrylic tube.
If you never even used custom loop or built one, I'd strongly recommend building a normal one first.
Thanks for the help guys , would i use the same fitting for the radiator as well?
I understand why most people would want/should use regular tubing but i have a spare pc to test and play with to get things right (as long as i order the right parts!)
Edit:
just checked my link i was up at 4am this morning and hadn't woken up properly i had just used the quick search on ocuk's website to get the link sorry guys!
First water real cooling I know you'll love it ( I know closed loop are real enough but not expandable which to me is the best thing about real water cooling, can be adjusted to suite your needs at the time)
Thanks for the great advice! i really can't wait i've got a little store of pc parts to go with the watercooling build but instead i've been side tracked by doing things like fence painting and garage painting!
Hopefully i'll get a project log thread up when i start i know it won't be anything special like twin water cooled titan black's or anything but im hoping to spruce up an old cm 690 ii , with a new window as the current oem one comes with a fan slot , swap out the psu for a modular one to make it neater and also sort out the cable grommets as the corsair one's arn't a fit. and obviously watercool the cpu but maybe go the PETG route if i can find out more about it.
