Morning All,
I was wondering if anyone could offer me any help or advice regarding the XSPC EX360 Crossflow Radiator.
Essentially, I am installing a new cooling set-up in a Cooler Master HAF X (Which I understand natively accepts a 360mm Radiator) - My initial thought was to attempt to find the smallest profile radiator possible, to prevent any modification to the case.....
I complied my order using the XSPC EX360, but due to its single pass/Crossflow nature I wondered if I would be better off with a Dual pass unit ? I plan on using a D5, and at this moment only plan on cooling my I-7, but have an intention to, at some point, install a GPU block for cooling a single 280X. *
Do any of you have experience with a HAF X and a 360 rad that you could recommend me ? I have seen lots of builds online, but am really unsure as to which radiator to go with to maximise the cooling potential.
So opinions on radiators if possible - And preferably ones that fit a HAF X, with 3 SP120's mounted on the underside...
Thanks guys...
-Vinny-
Thanks guys...
-Vinny-
