Xspc grx680 razor block
1 Mar 2011
Does any one have any thoughts on the XSPC gtx680 block. I'm going to get them for my system. Also are they compatable with the evga backplates.
Couldn't comment on the back plates, but afaik the EK blocks aren't compatible with EVGA backplates. XSPC not do backplates?
Look like nice blocks, though given the option I'd go for the swiftech hydrocopper for that card :D
I thought all the water blocks on the 680's use the same screw pattern? I know when installing the xspc block on my friends card last week it seemed that way so thought it would still allow the backplate to fit?
I thought most would use the same screw holes and as above worst case just use the 4 main Gpu screws. Its only as I have been doing my home work on water cooling i found many threads about Gpu backplates not being compatable.
Think I'll just go ahead and get them. If it doesn't fit not too much of an issue I suppose.
