Announced today the XSPC GTX 670 VGA Block. A superb looking block with real cooling capability.
This should be with us very soon and we are taking pre orders on the block now. Back plates are also available.
We have also added the block as an option to the Tech Labs cards
XSPC Razor GTX670 VGA Waterblock @ £79.99 inc VAT
We are proud to introduce our new design for Razor GPU blocks. We have continued with the styling from our RayStorm series so you can now have a full set of matching XSPC blocks. We have also significantly improved cooling performance by reducing the fin width from 1mm to 0.5mm, this dramatically increases the surface area.
Although we have used an acrylic top for aesthetics we have a thin stainless steel plate between the copper base and the acrylic. This allows us to use LED lighting, while keeping the strength and reliability of an all metal waterblock.
The new multiport connector gives you many choices for neatly routing your tubing. We have two G1/4? ports on the front and back of the block, two on the top, plus a side port, giving 7 ports in total. The multiport connector is compatible with our new SLI flow bridge.
- CNC machined copper base
- 0.5mm fins for high performance
- Stainless steel top
- Acrylic layer with 3mm LED holes
- Brushed aluminium faceplate
- Dimensions: 172.5 x 125 x 25.5mm
- Weight: 0.73kg
- Prepared for SLI with 7 G1/4" ports
- Supports GTX670 cards
(Nvidia reference design only)
Supplied with twin LED, mounting kit, G1/4" plugs, thermal pads and thermal paste
Only £79.99 inc VAT.
ORDER NOW
XSPC Razor GTX670 Backplate @ £15.98 inc VAT
Backplate for reference design GTX670 cards. The backplate helps cool the memory on the back of the GTX670 card.
- Dimensions: 172.5 x 98 x 4mm
- Screws: 8x M3, 10mm
Supplied with thermal pads and allen key.
Only £15.98 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom GTX 670 2048MB GDDR5 @ £394.97 inc VAT
The OcUK Tech Lab H2O GTX 670 combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent GeForce GTX 670 2048MB, the OcUK Tech Lab H2O GTX 670 allows for incredible overclocking potential on an already outstanding graphics card in a small and compact package.
This graphics card comes complete with your own choice of VGA block from industry leading manufacturers.
Choose the block that suits your own taste for a truly customised feel inside your system.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
- Core Clock: 965MHz (GK104)
- Core Boost Clock: 1045MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1344
- Shader Clock: 1930MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
From Only £394.97 inc VAT
ORDER NOW
- Weight: 0.73kg
ORDER NOW
ORDER NOW
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
