XSPC H1 Cube+
29 Aug 2010
Cornwall
Hi,
Has anyone used this case?
If so what's it like?
I'm guessing when used for air cooling it's not that good, but is it good for watercooling?
Is it easy to work with?
Although you can in theory attach a radiator to 5 of the 6 panels I'm guessing you'd have to leave at least 1 free so you could get access?
I'm wondering if it'd be better/easier to use than the Silverstone TJ11?
Thanks.
Its also cheaper, I like it, allot of radiator support too, probably more than the TJ11, 3 x 360, 2 x 240, 1 x 120. Looks quite modular too while being more unique than traditional tower cases.
Something like this would be on my shopping list if I had the room.
Edit: with all that room in the bottom no doubt you could fit something as big as a 560 too.
