XSPC Raystom - Poor So Far
16 Apr 2013
Just wanted to voice my current experience with the XSPC Raystorm kit, incase someone is thinking of getting one, or incase people are having similar issues.
The full 240 kit arrived, got down to installing it. Installation is pretty straight forwaed, and the parts look well designed.
Filled her up, turned her on, and worked lovely. Left it running to bed the system in and get rid of any air.
Next day, come to turn the PC on, working away for about 15 mins, then I get a CPU temperature warning. Only to discover the pump had stopped working.
Checked all the connections, ect etc, and nothing.
So had to call up the vendor whom sent me another one out. Arrived today, installed it in the system, turn it on..........thought there was a tactor in the computer!! The pump sounded terrible. So had to strip it all down again, then set it up as a loop on the desk to enable me to ensure their were no air blocks or issues. But the pump was still noisy.
So now waiting for my 3rd pump and only hope its 3rd time lucky.
Both the faulty pumps were from the same batch - P: #2#1815 N: 1820
Hi, Sorry, I thought the kit was called raystorm, so assumed each part was Raystorm.
Bu yes, its the Pump.
The 3rd one is on it way, if that doesnt work then yeah, I think they should send me a D5 :D
I was new to water coolong and went with the RX360 kit and have to say how pleased I am with it. It has been going strong now for over a year with no issues at all. The D5 pump is top quality IMO.
Hope you get ya pump sorted. Third time is a charm :)
The kits are put together as a easy option so you don't have to go purchasing individual parts. You can up grade any single part such as the pump or fittings or tubing ect.
