XSPC Razor SLi Bridge
I know there on the xspc sites, maybe get a thread in customer service and see what they say.
Btw I have the new 7970 version and it's a nice bit of kit, looks and feels great and keeps the temps low.
XSPC Razor SLI Flow Bridge @ £8.99 inc VAT
Easily connect two or more blocks in SLI.
Compatible with Razor GTX680 GTX690 and Razor 7970 (New Style) blocks
Only £8.99 inc VAT.
ORDER NOW
Awesome. Would be cool if these coincided coming in at the same time as the NZXT Phantom 820, because then I'd have absolutely no excuse to not order an additional 240mm rad, pump and res at the same time.
Thanks a lot.
Top product. I have 2 of these for parallel on GTX680's. They make the SLI set up solid as a rock and feels like one big duel slot card. Easy to get in and out of the system. Plus they look the muts nuts too.
Are there ones for larger gaps between the cards?
You shouldn't need a larger gap.
The biggest problem with SLi/Xfire with air cooling is indeed the limited gap to allow sufficient air to flow into the upper card due to motherboard limitations. I'm using an Asus R4E and currently I'm separating the two air cooled GTX670 cards by leaving a free slot between them which isn't something you can do on a lot of motherboards. Also, doing this I'm wasting a slot in between the two cards
Since you're watercooling two cards you don't need to worry about the airflow so much and therefore the two cards can go straight into adjacent slots without worry.
True, but I think if you don't use the slots specified in the manual then one slot will only run at 8x.
Since I'm running PCI-e 2.0 I'd like to keep running at 16x.
If you're not running on an Sandybridge-E X79 based board then your SLi/Xfire config is going to be running x8/x8 anyway. You can't run SLI with x16/x16 on any other platform unless the motherboard uses a PLX controller or some other similar device.
I just checked your sig and it seems that you're using the same CPU as me. In which case you've got x40 lanes available and therefore pretty much all your slots should be x16. I know all the red slots on the Asus R4E are all x16 and it will only drop to x8 once you're using more than 2 slots.
Since you're using the same board I can confirm that you can have a gap when aircooled and they both work as PCI-E 3.0 X16, and they also work the same way when they are adjacent. Stay in the red slots and you're fine.
They are called "Razor", and yes they are compatible with the 670 version of the Razor block. I have two of them sitting here waiting to go into my PC and the manual for them details the use of the SLi bridge - hence why I started this thread.
I won't be installing them until I've got my new case which will give me room for another rad internally. I could hang it off the back or mod the case some but I want to keep everything internal and unmodded and so I'm waiting on the NZXT Phantom 820 to start shipping and then move my rig into that. Once it's in I'll have a better idea of what additional water cooling gear I will need.
