**XSPC RELEASE A NEW DESIGN WATER BLOCK...OOOHH SHINY**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
XSPC have been working hard to come up with something new for there range rather than the usual black and white offering that is released when a new CPU comes out. The new Range is called NEO and in my opinion looks really nice. Obviously with the current market the water blocks do include RGB lighting which can be turned off but it does mean that you do not have to buy an extra LED if you want to change colour.
The blocks are available in Chrome and Black chrome and work with either Intel or AMD sockets so make sure you select the right model.
With chrome fittings these blocks look awesome.
Product Description:
The RayStorm Neo combines the high performance of our RayStorm Pro block, with a premium new look.
Each waterblock is carefully machined from pure copper and acrylic, while the hold down bracket is machined from solid aluminium. As with all XSPC products, no aluminium is used in the coolant flow path.
The RayStorm Neo offers outstanding performance, low flow restriction, RGB lighting, and thanks to our new mounting system it’s easier than ever to install.
Supplied with a multi function RGB controller and two RGB LEDs.
- High performance copper base
- High quality acrylic top
- Solid aluminium bracket
- Low flow restriction
- RGB Lighting
- 2 x 2x5x5mm LED holes
- G1/4" threads
- Compatible with most compression fittings
XSPC Raystorm NEO Waterblock (Intel) Chrome @ £79.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-neo-waterblock-intel-chrome-wc-440-xs.html
The RayStorm Neo combines the high performance of our RayStorm Pro block, with a premium new look, Intel 115X /2011 and LGA 2066 Sockets, RGB Control
Only £79.99 inc VAT.
ORDER NOW
XSPC Raystorm NEO Waterblock (Intel) Black Chrome @ £79.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-neo-waterblock-intel-black-chrome-wc-441-xs.html
ORDER NOW
XSPC Raystorm NEO Waterblock (AMD/AM4) Chrome @ £79.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-neo-waterblock-amd-am4-chrome-wc-442-xs.html
The RayStorm Neo combines the high performance of our RayStorm Pro block, with a premium new look, AMD AM2+ / AM3+ FM2+ AM4 Sockets, RGB Control
ORDER NOW
XSPC Raystorm NEO Waterblock (AMD/AM4) Black Chrome @ £79.99 inc VAT https://www.overclockers.co.uk/xspc-raystorm-neo-waterblock-amd-am4-black-chrome-wc-443-xs.html
ORDER NOW
All XSPC Water cooling products can be found here
So they have released a "new" block which is now not only rgb it's shiney too? Are there any other enhancements over the standard Raystorm as I have one of those and it's brilliant.
The Block has the same performance as the Raystorm Pro. This Thread is mainly to show off that XSPC added yet another variety of colour to the range giving people more options.
The performance of the Raystorm Pro is really good so it will hard for them to improve on that.
