Hi All, im going to build my first computer this weekend and i have got all my bits and pieces together. I was just wondering if the XSPC RS360 Radiator is going to be good enough to cool in a CPU loop.
The water cooling bits i have got are
alphacool vpp655 pump
ek d5 acetal top
ek supreme hf nickel plexi cpu block
ek bay spin resovoir
XSPC RS360 Radiator
loads of compression fittings and tube 1/2 inner 3/4outer
6x coolermaster sickleflow red 120mm fans (im going to use them for push/pull)
the water cooling is going to be cooling an i5 2500k on a z68 asrock fatal1ty mobo.
the rest of the specs of the computer are
xigmatek elysium case (absolutely massive)
8gb gskill ripjaws x 1600mhz
128gb corsair force ssd
akasa six channel fan controller
1x xfx 6970 gpu
850w ocz psu
i plan to mount the rad in the top of the case. v excited but i hope that the rad will be ok?
cheers
minty
ek d5 acetal top
XSPC RS360 Radiator
1x xfx 6970 gpu
850w ocz psu
cheers
minty
