XSPC X2O 750 LED's
5 Jul 2012
Sheffield, UK
Is there any place I can get different coloured / replacement LED's that will fit the in the XSPC X2O 750's LED holder that anybody knows off that connects to a molex adapter in the same way?
Basically I have red ( kind of orangey tubes ) and want to use red dye to make the tubes appear well redder. But the XSPC pump uses a blue LED and I like the illumination it creates. Should I just remove the LED and choose a bright red or can I actually get red replacement LED for this thing.
