- 16 Jun 2005
- bolton
Hi i did a install a few days back, i used a extreme light version of xp pro it was only 115 mb and it was a lot faster than the full version i own, the only problem i had was when i tried to install my voyager 1055 usb adsl adapter, initially it did install but i could not enter the mac code as usuall, obviously some files were missing but i dont know which and when trying to go to add remove/add windows components it stated than another instance of this programme has allready started therefore i must wait for it to finish but it never finishes, also when tryin to install optional windows components off the cd i got the same scenario, does anyone know what files would be needed so i can get them on a slave drive and when i reinstall the light xp everything goes well?
