Xubuntu + Q6600 680i SLI not throttling
29 May 2012
Dorset
Ive just built my old pc up as a server, pulled the 8800gtx and installed xubutu to replace my aging sempron box. Works fine everything as it should do, but the cpu isnt throttling back anymore, ive ran up cpufreq-info which tells me ive got no drivers installed for throttling, now Ive factory reset the board and tbh its been unplugged for 6 months anyway so everything in the bios is set at defaults and even before it was throttling fine under windows.
Any thoughts as to why I cant get it to drop from 2400 I dont really want it running full throttle all the time as even though its not loaded it will be using more power than really needed
