- 28 Jul 2007
Hi. Hopefully someone wiser than me can help me on this one.
Im trying to convert an xvid to dvd so it is playable on a standalone dvd player. I am having some problems though.
When the xvid is converted to dvd, the audio slipps out of sync on the resulting dvd file. This is the case with numerous converting programs.
After searching on the internet for guide, all i can find are guides which involve converting the sound and the video separetly then joining afterwards and THEN burning. This seems like a very long winded way of doing this. So my question being is there ONE utility to do all of this(there must be) or is this the only way?
What is the cause for this 'audio slip'? Is it something to do with frame rates? I should probably mention that i am making a PAL dvd.
Sorry if this has already been discussed, but after a search on here i couldnt find anything.
Thanks for your time.
