Xvid to Divx compatibility - can i get away with not re-encoding?
3 Jan 2004
Bournemouth
Is there a simple way to make xvid files compatible with DivX players?
Hate having to re-encode everything
Get a hold of little program called AVI fourCC changer. When you run it you can change the headers on the file to DIVX and it'll play as a divx file.
Regards,
Whammer
Marcos:
If I remember, Xvid is simply the "open source" (I think that is what you call it) of Divx, so I think it should play on a Divx player without any re-encoding (by simply burning it, as Lonewolf states, as a data file). :)
Regards,
Whammer
i'll try it thanks
jbloggs said:
Marcos:
Doesnt work on my divx media box drive thing :(
if anyone has any xvids that are jerky on standalone player
download mpeg modifier and 'unpack' it using that, and save again as avi (takes about 30 secs) this'll fix it!
My problem is not jerkyness, when i try to play xvid some dont have image at all (black screen), some have what appear to be semi-inverted colours all over (strange effect)
I get more compatibility using the PS2, but it does have slightly jerky playback, i'll try that unpack thing to see if it solves it.
Regards,
Whammer
What settings do you suggest i use on the program? The media drive is compatible with divx 3,4,5 i think
whammer said:
Marcos,
I don't use the presets in the program, I type "DIVX" in the two boxes. Works a treat with my fussy DVD player.
Regards,
Col
i tried your way, a little progress, the video is still not coming through, just black. The audio works fine, but when i press the volume (on the media device) the volume bar comes up and a part of the video is playing behind it.
So its there, and it can somewhat decode it, but not quite right yet
And then, just like that....another Xvid file works straight away without any modification? :confused:
maybe its just that one file
Xvid files generally play on divx devices, perhaps that file used a more advanced version of the xvid than the media box can handle.
