XviD to DivX
7 Jul 2004
Gloucester
My standalone DVD player jumps very slightly sometimes while playing XviD, not a lot, but just enough for you to notice.
Are there any programs about that can quickly convert XviD to DivX keeping the same quality (or enough of the same quality that you woudnt notice the difference in a normal TV?
it might just be a packed bitstream
download "mpeg modifier" you can unpack it (using 1 tick box) and resave the avi
takes about 2 mins per avi :)
could also be a dodgy 24 -> 25 fps conversion (ie inserting a double frame every second often leading to a jump)
Use gspot to identify exactly what your avi file is.
