Hey Guys looking for some help Y-Cam YCBHD5 Cube HD 720p Im looking at installing one to keep an eye on the puppy that we are going to be getting soon, on the manufactures web page it says that
“PoE Accessory
Offering heightened flexibility, the Y-cam Cube HD 720 can connect to a simple plug in PoE accessory allowing users to switch between Wi-Fi and PoE, optimising installation possibilities and perfect for installers and end users alike that wish for a convertible and flexible solution.”
Have I to assume from this that I could connect this cam up to my network via power line plugs? I just want to be able to log in using my phone in the day when I’m at work to check on the puppy that’s all i don’t need it to record at this stage, I’m just to too sure if it will automatically switch off the wireless side of it when the Ethernet cable is plugged it to it, and will i be able to assign it a static ip address?
Thanks for the help
Craig
“PoE Accessory
Thanks for the help
Craig
