Currently using 10 Scythe GT's AP-15 on a Lamptron FC2, 8 on 2x 120.2 rads in push/pull and 2 as case fans (2 per channel using y splitters) and i am looking to upgrade my case and add in a 120.4 rad, i will be adding a 140mm front intake fan and one of the GT's will be a rear exhaust and in total i will be running 16 GT's on the rads in push/pull, i will need to be running these 16 fans in banks of 4 per channel and was wondering if i used 3 y plitters for each bank all the power for 4 fans will go running down a single y splitter to the controller, now i know the controller can handle this as it is rated for 45w per channel but can thoes y splitter cables handle the startup current of 4 of thoes fans ?
