- 20 Dec 2008
On my Yamaha YBR I replaced the clutch clamp that holds the lever on to the handlebar, it was a bit tricky and I had to pull on the cable to get enough slack in order to get it through the new clamp and back into the lever, I wasn't too rough but it did require using all available slack which I assume was already being used. The cable is only 2 months old.
I get the lever back on the handlebar and tightened and what's happening is when I hold in the clutch the back wheel does not freely spin, it's very stiff but not completely locked so using the clutch does do something. I'm not sure if this is normal but I have not noticed before.
In first gear with the clutch held in engine on the back wheel spins pretty fast, I can't stop it with my hand. I've loosened the clutch cable and tightened it but neither makes a difference. Have I knackered the cable do you think, or is the back wheel not supposed to move too freely while holding the clutch?
