Yate loon stock?
Anyone know when the Yate loon 120MM fans will be back in stock?
Mainly THIS one
Dimensions: 120 x 120 x 25mm
- Rated speed: 2200 RPM ±10%
- Sound: 40.0 dB(A)
- Air flow: 88.00 CFM
keep in mind the yate loons from the place in the states that get them direct from the manufacturer that are highly rated aren't the same quality as the more common ones available most other places, and in general it seems as if Zalmans push more air, for less noise than even the good Yate Loon's, let alone the more generic Yate loons most people stock.
In other words, Zalman's rock and cost the same, quieter + more airflow and considering you don't know which Yate loon version you're getting, the good or the bad ones, its a no brainer really.
http://www.xtremesystems.org/forums/showthread.php?t=171661
in the medium fan speed you see the yateloon, the non petra are the "worse" yate loons that are noiser and have more weird rattles and so on when undervolted. Generally the futher and higher to the left at any point the quieter the fan is or the more airflow it gives. Zalman, on or off a radiator, ie case fan or stuck on a sink/radiator its almost always giving the most airflow and the least noise. THe good yate's get close but can't beat it, the less good yate loons aren't that far off, but for the same price, the Zalman is the best. between £4-5 and very easily available, you can't really find a good reason to go for anything else tbh. It also, I believe, comes with a resistor cable so you can run at 7v without needing to add it to a fan controller, which can make life easier aswell if you want to run it quieter.
