I'm going to be buying a Zalman ZM-MFC2 fan controller and I have some questions on that controller and also on the Yate Loon's I'm getting too.
1. Regarding the Yate Loon's... Would it be better to the get D12S-H over the L version if I'm getting a fan controller so I can get a high punch from fans should I want more airflow on hots days. Although I'm wondering will the the "H" fans be much louder than the "L" fans at the lowest setting due to the higher airflow/dbA ?
2. Can the Zalman ZM-MFC2 automatically control the fan speeds based on temperatures inside the case? Couldn't find the info if it could or not, as this would be really handy, saves having to keep turning the dial up / down
3. And last one... can the Zalman ZM-MFC2 change individual fan speeds of fans, or will it just change all fan speeds at the same time?
I guess one later question, are Yate Loon's the best fans to get for airflow/noise? I'm looking for as silent as possible with the best airflow.
Thanks!
Thanks!
