Hi Guys
I've managed to hang on since just before Ryzen was released but now is the time..
I dont upgrade often. Only recently upgraded my 8800GTX to a 1070 which I may sell and go for 1080ti as I should be able to sell for at the very least what I paid for my 1070.
So coming from a i7 920 what would be a safe bet.
No budget per say. I'm not going to spend £5k but if it needs to be £2500 then so be it.
You can leave the case. I'm not decided whether I should be daft and the Enthoo Primo Elite. Or just a Primo and put the difference to more Ram or the 1080ti
I game a 4k@60hz on my Hisense Tv. Or oculus rift (Elite dangerous)
I also photoshop and run some routing software (logistics) for work.
My thoughts were
My basket at Overclockers UK:
Possibly a new PSU as mine is a few years old currently a Corsair HX850.
The GPU can change I just like the thought of AIO
And I'll want an AIO for the CPU any suggestions
I wont be overclocking.
So how much of the above is overkill?
My thoughts were
- 1 x AMD Ryzen Threadripper Sixteen Core 1950X 4.00GHz (Socket TR4) Processor - Retail= £899.99
- 1 x Asrock X399 Taichi AMD X399 (Socket TR4) ATX Motherboard= £359.99
- 1 x Team Group Xtreem "8Pack Edition" 32GB (4x8GB) DDR4 PC4-25600C14 3200MHz Quad Channel Kit - Black= £389.99
- 1 x Gigabyte Aorus GeForce GTX 1080Ti "Waterforce AIO Xtreme Edition" 11264MB GDDR5X PCI-Express Graphic= £869.99
I bought an 8GB kit of DDR4 Ram and received the same amount. They should have sent you a full box for spending that much
