yellow led for xspc raystorm
15 May 2012
Louth, lincs
not got the block just yet so dont know the size and where to look, any ideas folks????
could i just get some yellow led's, cut the blue ones off and solder the yellows on??? cant be a hard job????
one of overclockers competitors sell them, can't say which but they do them in the required 3mm size and will fit snug in the block. they come prefitted to a molex plug as well so plug and play pretty much.
3mm is correct. Phobya are bound to do them.
so i'm looking for 3mm, thankyou
to add was gonna use the ek plexi block but was a bit worried about cracking so gone for the raystorm and hopefully with a yellow glow.
Yip - as per above - you can get various colours. Not too costly either tbh.
