Yet another building a PC for my son thread
24 Apr 2011
Hi all,
I'm looking for some advice me and my partner have saved £1000.00 to build a computer for our son looking for a tower and monitor setup for this price. He primarily plays fortnite non-competitive with family, friends etc. Im thinking these are the options available
AM4 playing at 1440p decent settings
AM4 playing at 1080p with great performance
AM5 playing at 1080p but might handle 1440p lowered settings
Some input from me , only needs 512gb NVME, 27inch monitor preferred 75 mhz+ is fine, only new parts
he currently HOGS my system so he is used to Ryzen 7 5800X3D with a Radeon RX 6750 XT Red Devil 12GB
any help is appreciated
Graphics card is difficult for this budget, personally I'd prefer a 7600 XT 16GB or 6700 XT 12GB (as close to £300 as possible), but the 4060 does have decent power consumption if you'd rather nvidia.
Having the 12400 is better if you can afford it, since it gives a graphics card is the main one dies, which can at least be used for e.g. school/college work.
My basket at OcUK:
Total: £998.90 (includes delivery: £0.00)​
I have gone the Am4 route.
My basket at OcUK:
Total: £941.88 (includes delivery: £0.00)​
You could 'upgrade' to 32 gig of ram but in general its pointless for gaming.
All the items that are pre-order are in stock at other places and 1 is even cheaper than OCUK.
Just add a peerless assassin for about £30 (which is overkill for a 5600) as it will easily cope with any upgrades later on and will fit in the case.
dfour - Any reason you've gone B550 instead of B450?
On the other recent thread the Ryzen 7600 build seemed sensible, go with a cheaper GPU for now and when upgrade time comes around do graphics first then you also have the luxury of almost every other AM5 chip to choose from.
On the am4 b550 are more readily avalable, you probably wont save much from b450 to b550 and you would lose pcie 4 on the b450 boards
