Yet another hello & some help required.
18 Mar 2011
East London.
Hi all, been on this forum a little while and its great, with some top notch advice.
What i would like to know is that i understand there is something called 'MM' here. Somewhere where members can buy and sell their goods?
I also understand that there is a number of posts the you have to make before you can take advantage of it- 200 if im right?
What i would like to know is how can i make some random posts to get to that number without spamming of course and then secondly how do i access the MM
thank you
EDIT:- See below
Access to the Members Market forum requires two things. Firstly, you will need to have over 250 posts and have been signed up for at least 90 days. Please note that this does not mean you spam the forums simply to increase your posts, as this action will result in posts being deducted, and if you continue this behaviour, your account will eventually be banned/suspended. Once you reach 250 posts, you will need to activate your trust. This is either found in your UserCP, or you can press the trust button that appears at the bottom of all your posts.
