- 27 Apr 2004
- In bed with your sister
Sorry about another "spec me a monitor" type thread guys but I'm looking to spend a fair wad of cash on a new monitor and want to make sure I get the right one.
Basically, what I want is a large, widescreen monitor which will be used mainly for multimedia but I want to start getting into gaming too (bit late in life really but hey
Resolution shouldn't be a problem as the spec of my PC (below) should easily cope with pretty much anything.
Money is not a major problem - I am willing to spend up to £2000 to get the best kit.
I need a good quality monitor which will serve both purposes well.
Machine spec:
AMD Athlon 64 X2 Dual Core 4400+
Asus A8N-SLi Premium nForce4 SLi
Corsair 2GB DDR XMS4000PT TwinX
ATI Radeon X1800 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI
Western Digital Caviar Special Edition 250GB 2500KS SATA-II 16MB Cache
Antec SLK3800BUK Black Quiet Midi Tower Case
Thermaltake PurePower 680W ATX2.0 Power Supply
I am using the onboard sound with a set of old 5.1 Videologic speakers at the moment which will be upgraded eventually but the current system isn't bad and won't affect my choice of monitor.
I already have a Vusys HD19A which is a good enough desktop monitor but I don't think it would be the best as far as gaming is concerned (but then I know virtually nothing about monitors - I have other lower spec machines I can use it for, anyway).
Thank you in advance for any advice
Stan
Machine spec:
Stan
