- 18 Mar 2011
- East London.
I have the following:
i7 2700k OC'd to 4.7 @ 1.27v / 5.0 @ 1.30v
1 x HD 7950 twin frozr, at stock but will be OC'd to max.
2 x Crucial m4 SSD's
1 X D5 vario pump.
1 x lamptron touch fan controller.
2 x 3mm xspc twin leds
5 x scythe gentle typhoon fans 1850rpm
4 x usb 2/3.0 devices using mobo power
1 x external dvd/rw using usb power from mobo
1 x keyboard
before you ask, yes i have used the various psu calculators out there and keep ketting inconsistent results. they vary from 450 - 580W.
curent psu is a seasonic platinum 1000w. over kill but i bought it anyway, the power switch on it is defective and has problems powering the pc up. this time i would like to buy something a bit more 'sensible' so hence asking here.
moslty used for gaming and video conversion as well as daily pc tasks.
Thanks.
1 X D5 vario pump.
1 x keyboard
Thanks.
