Ok, I have a Q6600, which, when I first got it, after experimenting with some clocks, the highest idle temperature I had was around 35c with speedstep disabled, and approximately 45-50c at 100% load on all cores for 5 minutes.
These seemed like safe temperatures to me, and left me feeling a little safer as my machine is on 24/7 (May it be noted, the weather was hotter when I first built the machine a few weeks back)
Now, with a lower voltage (1.46v bios, and around ~1.42 actual @ 3.3ghz) temps under speedstep are around 44c, and idle temps with speedstep disabled are around 50c, with 100% usage around 60-70c)
Being that my chip is supposedly guaranteed to run 3.3ghz (I went for the Guaranteed one for a bit of peace of mind, as the only reason I purchased a Q6600 was to reach such a speed) would that be considered too high operating temperatures for 24/7 use?
Now, I understand that dust can cause higher temperatures, but such an increase after just 3 weeks?
I'm using an ACF7 with the pre-applied thermal paste.
I'm perfectly aware of the "safe" operating temperatures for the Q6600, but does anyone have any suggestions?
or buy smaller deltas like EFB1212SHE the ones i am using are beyond insane
