Yet another which fan thread! (140mm)
3 May 2004
Hi,
Im looking to replace the front 200mm fan in my Enthoo Pro case with two 140mm fans (or 120mm if there is something better) as its a bit loud and annoying.
Which fans should I be looking at for quiet/silent operation but still delivering very good airflow?
Prefer not to have LED's but its not a deal breaker.
Thanks for any help!
I got those fans above and they certainly weren't quiet imo, way louder than the bitfenix spectre 120mm fans they replaced, the fan itself was quiet but the sound of the air being pushed through the grille was unbearable.
Thermalright TY-140 series fans. They perform as good if not slightly better than Noctura counterparts and much lower prices. Just wish they came is 140mm square housing.
I have a Noctua NF-P14r REDUX and can't really recommend it. It's fairly loud at 1000rpm and doesn't move a huge amount of air.
Seems noctua have been sitting on their laurels and other fan makers have caught up with cheaper fans.
