Just built myself a new system to sit on the network as storage.
Using a Netgear WGT624 router and WG11T adapters on both machines.
XP pro is installed on the existing machine, and an nlite'd copy of xp pro on the server.
Both machines have excellent signal strength and the netgear software shows either 56mbps or 108mbps - yet whenever I try transferring anything over the network it hardly creeps over 4mbps - and just transferring a single 75mb file will cause the connection to drop.
Screenshot is of a transfer of the june2008 directx update. Just seconds after the screenshot the connection dropped off, then reconnected, and of course the file failed to transfer.
I know I was never going to get anything like the throughput of a wired network but surely it should be better than this?
